AIWA Headphone Stereo Catalog 1989
Discussion in 'Brochures, advertising, data & specs...' started by Mister X, May 15, 2019.
    This was found in the forum reader, I'll update with the original poster if I can find it. I saved these beautiful scans, while most manufacturers were cranking out crap, AIWA still had a huge line-up. Around 1992, minority share holder Sony gained majority control and turned the line into a budget offering, a sad fate for a great cassette player manufacturer.
    Patex, AE_Stereo, Silver965 and 4 others like this.
  2. Radio Raheem
    i have the hx p303, a superb walkman
  3. Silver965
    Silver965 Well-Known Member
    Torino
    Thanks Mister x I had not yet seen this tred
  4. TooCooL4
    Wow this catalogue brings back some very pleasant memories, I had the HS-JX101. I wanted to try the HP-V99 earphones but could never find one.
    Emiel and Mister X like this.
    There's a ton of brochures in the "forum reader" link, unfortunately sometimes when you search them through google it only gives a link to the graphics file. I wasn't the original poster, thanks to whomever put it up!
  6. Emiel
    How did this bi-azimuth head alignment work? Was is it pure electronics that made it happen, or a plunger/actuator?
  7. Emiel
    A few years later, I picked the ultra thin Aiwa HS-EX2000 out of such a catalog. Amazing device, except for this proprietary lead acid gumstick battery. Good to have cheap battery alternatives nowadays that actually get you through at least half a day of use without the large external 2x AAA battery holder.
  8. AE_Stereo
    AE_Stereo Active Member
    UAE
    Making smartphones are much easier than these tech packed electro-mechanical devices. Software will do everything!
    Sadly missing the original Aiwa.
    Reli, Mister X and Emiel like this.
  9. Emiel
    Off-topic:
    From the Sony catalog I purchased a micro hifi set. Still going strong after 20 years, but now it needs to go:
    I never cleaned the head and capstan before, but today I did and was surprised that the rotating record/playback head made it into the cheaper range:
    If someone has this catalog, I would appreciate a link!
    Okay, back to the topic.
  10. Emiel
    It looks like other brands like Sanyo had a similar configuration, although not marketed as bi-azimuth adjustment:
    http://stereo2go.com/forums/media/sanyo-jj-p4-14.1650/full
    Silver965 likes this.
  11. Reli
    Reli Well-Known Member
    Amazing the features packed into these things, and with higher quality than most full-sized boomboxes
