When discussing in a particular thread, many members interact. Unless you're very quick replying, sometimes you want to leave your reply to other than the newest comment... but that makes the whole thread a bit of mess, because it's not clear who did you want to reply to. Quoting is very helpful then. There are several ways to do that, all of them very easy to use. 1) Using the '+Quote' small link at the bottom right side of every comment. Once you click on one of them , the system saves it, and changes its aspect to '-Quote', meaning that you can remove it if you wish. Click on every comment you want to quote. 2) Select any text of any comment you want to quote in case you don't want to quote the full comment, and a small black button will appear under the cursor. click +Quote to add that selected text to the list. When you're done, scroll all the way down and click on the 'Insert quotes' button. A small window will appear so you can confirm and finally insert them in your reply. Then you can simply write your replies between the /QUOTE mark that indicates a comment ends and the QUOTE that means another comment begins. Don't delete these marks or it will become a little mess... That's it!
