Hi to all
Discussion in 'Introducing myself' started by Pip, Jan 12, 2018.
  1. Pip
    Pip Member
    Netherlands
    Hi I am Philip from the Netherlands , but just cal me Pip.
    Love trying to fix some old walkman (beginner, much to learn) and yes already have two working; a dd11 sound problem new capacitors (first time SMD with special thanks to all writing there expertise here) and a dd33 center gear replacement (special thanks to mihokm for making the sony dd step by step repair guide and the great ebay service )
    My new project is a DC2 (Think I made some soldering mistakes putting it back together, no sound and power is not turning off with batteries inserted, it keeps spinning)
    Pip
  2. TooCooL4
    Welcome to Stereo2go Pip :wave:
  3. Pip
    Pip Member
    Netherlands
    Thanks
  4. Roman666
    Roman666 Member
    Spain
    Welcome, Pip! You'll learn a lot in this place. Granted
  5. Pip
    Pip Member
    Netherlands
    Thanks, I am looking forward to it.
  6. Pip
    Pip Member
    Netherlands
    It was not a soldering problem.
    Connection switch was blocked and head was not inserting the tape due to some bad plastic below the center gear (luckily I had a spare part)
    Now power is fixed, but need to open it again play and forward is blocked somehow, it turns a little and then stopes (rewind works)
    I can hear a sound in my headphones again (no music due to the play block)
    First back to reading the beginners manual again
  7. Mystic Traveller
    Pip mate, welcome to S2G! :wavey:
  8. Pip
    Pip Member
    Netherlands
    Thanks
  9. Pip
    Pip Member
    Netherlands
    With no cassette inserted all work.
    With cassette inserted;
    • play OK,
    • forward OK,
    • rewind blocks after two seconds
    • and stil no music.
    Next step
    • check capacitors
    • search forum (rewind problem)
  10. Pip
    Pip Member
    Netherlands
    rewind OK
  11. Brutus442
    Brutus442 Well-Known Member
    Toronto
    Hello PiP!
    I to came to S2Go looking for help and found too much of it! Now I'm hooked:wavey:
  12. Pip
    Pip Member
    Netherlands
    Hi Brutus442,
    Yes, a lot of info here.
  13. Pip
    Pip Member
    Netherlands
    Player brought to a professional, they have better equipment.
    • Repair music problem
    • allround check
    • Update old components
  14. Pip
    Pip Member
    Netherlands
    Next project D3:
    • New center gear
    • Repair rewind gear (I had to cut the gear with a sharp knife and glued it to a spare dd33 gear)
    • place new belt (old one is melted)
    • repair phones (had to replace it)
    And thanks to this forum, all up and running with no click.
  15. Pip
    Pip Member
    Netherlands
    DC2 is repaired and tested: PCB connection (manual item 502) was broken.
    Capacitors tested
    Al works.
    Cost €75,-
  16. Boodokhan
    Hello Pip
    welcome to the forum.
    Please take some pictures of devices you fix in the future. I would love to see how you fix thing.
  17. Pip
    Pip Member
    Netherlands
    Sorry, I'm Stil finding out how to upload photo's, I have no Picasa and did read the tutorial.
    maybe in a few days I make a new post
