Lithium replacements for the NH-14WM batteries?
Discussion in 'Discmans, Minidisc, DCC and other players' started by Spookex, Dec 22, 2023.
  1. Spookex
    Spookex New Member
    Japan
    Hello there,
    Has anyone had any experience with those Aliexpress USB-C re-chargeable Lithium batteries that mimic gumstick batteries?
    I bought a used WM-F701C, but have no batteries for it, so I'm at the crossroads of buying a set of no-name NI-MH batteries on Amazon + an old Sony battery charger or one of those lithium batteries since they are around the same price in total.
    I did buy one of them as a PS-S5 replacement for an Aiwa HS-JX707 that I was trying to repair but wasn't able to test long-term performance since I failed to fix it before moving to Japan.
    Cassette2go likes this.
  2. Emiel
    I have one and it works just fine. Don’t know if the 800mAh is ‘real’, I simply charge when needed via USB-C.
    You can’t judge the battery status on the LCD on the unit or remote though: the status appears as full, until it dies.
    I prefer it over the newer NiMH batteries, simply because those old chargers have not a lot of battery management intelligence in them. The batteries get really warm as well when charging in those bricks.
    Spookex likes this.
  3. Spookex
    Spookex New Member
    Japan
    Any feedback on the playback time compared to NI-MH or NI-CD batteries?
  4. Emiel
    Not really, as the cells you get with these oldies are usually no good due to age.
    I use the later MiniDisc portables with the gumstick for several days on low to mid volume with IEMs.
    They will not be as good as the NH-10WM (or 14) for that matter, the capacity is simply lower.
    However, there is no memory effect on the Lithium ion replacements.
    Since there are relatively affordable, I would not even consider buying the regular replacements.
    Spookex likes this.
  5. Spookex
    Spookex New Member
    Japan
    Then I'll go for lithium, might eventually get around to testing the true capacity since I have one of those inline USB charging testers.
    Emiel likes this.
  6. Emiel
    Yes, please test these. As you can see in the photo I attached, only the form factor seems to differentiate the 3 I have.
  7. JediJoker
    JediJoker New Member
    West Coast, USA
    Did you save the link(s) for where you bought those? I searched for "mr chan batteries" and didn't find these models.
  8. Cassette2go
    I've bought these in the past. I have two of them presently.
    Just found this amazing item on AliExpress. Check it out!
    $22.28 | 100%new USB TYCP-C 3.1 battery for sony NH-10WM NH-14WM NC-6WM for Panasonic HHF-AZ01/RP-BP80/RP-BP61 For SHARP AD-N55BT
    https://a.aliexpress.com/_mMfaX3I
    JediJoker and Emiel like this.
  9. Cassette2go
    https://a.aliexpress.com/_mMtbrz2
    I have two of these batteries and they work fine.
  10. Emiel
    Or check eBay: gumstick lithium
    JediJoker likes this.
  11. JediJoker
    West Coast, USA
  12. Cassette2go
  13. Emiel
    You can check mdgadgetry on Instagram too. I did order several items from the store.
    JediJoker and Cassette2go like this.
