MD Walkman only plays pre recorded MD's
Discussion in 'Discmans, Minidisc, DCC and other players' started by Silverera, Sep 4, 2021.
  1. Silverera
    Silverera Active Member
    MEL
    Recently acquired an MZ-R50 Walkman for $42 as a donor for parts. Described as working by the seller but I find that a broad claim when buying ex Japan. I noticed it was fine playing a pre recorded MD but started to skip and stop reading any MD recorded on other units. Then I flipped it over and it played any MD right through without Disk Err message popping up. Reminds me of the notorious issue with the D350 Discman which only plays when held at 45 degree angle. In that case it's the spindle motor main bearing wear. The MD problem I thought was lack of power on the Laser unit as it requires more power for non reflective surfaces on recordable MD's to get reliable reads and transfer to the DAC. However before dismantling and attempting to adjust the Laser pot if you have an MD not playing recordable media I suggest the flip test. If the Walkman plays its not Laser power that is the problem but most likely the flimsy plastic guide that supports Laser transport. These tend to sag over years of non use and it's enough to interfere with the focus of the Laser on the disk surface. Flipping the Walkmsn over seems to negate the effect of gravity on this guide restoring focus and allowing the recordable media to play correctly. So wondering what the fix involves to restore normal functionality when this fault occurs. Many others I am sure have this issue with MZ-R30 and MZ-R50 recording MD Walkman.
    Emiel likes this.
    Should they be stored upside-down then?
  3. Silverera
    MEL
    I haven't decided how best to fix the problem if it is indeed the effect of gravity long term on that plastic guide that is part of the Laser assembly. So far storing it for a few days inverted has not rectified the problem. Maybe longer term it would have some effect. If it's more to do with the degeneration of the plastic over time it's probably not going to matter how you store the Walkman. Only replacement of the laser block will restore it and of course any assembly you acquire from the same model donor MD Walkman might not be any better.
    Is there any lubrication on the guide? I've only attempted one MD repair and it was a different issue, I don't remember what all of the internals looked like. My other units all work fine but they don't get use.
  5. Silverera
    MEL
    There is no evidence of lubrication and given the proximity to the Laser lense I doubt any could be used. It seems yet another case of plastic fatigue to go with DD Walkman CG, D250 Discman central gear and small reel gear in WM-D3 Walkman Professional. Ugh...plastics!!
  6. Outland
    Outland New Member
