Mods for the Panasonic RQ-S60/80
Discussion in 'Tech talk' started by Command8, Dec 20, 2016.
  1. Command8
    Command8 Active Member
    London
    Hello everyone, I recently ordered a panasonic RQ-S60. A cool mod i found for is this:
    https://lifehacker.com/5625612/make-a-hybrid-iphone-headset-that-actually-sounds-good
    Since the Panasonic RQ's aren't as functional without the included earphones, i spliced the earphones with higher quality Philips earbuds. I wanted to use my best earphones (remax 610d) but didn't because i think ribbon cables would have been incompatible (i dont have any soder).
    Also if you dont have any solder on you, using plastic tape, nail clippers, lighter and wire connector nut is a-ok :thumbup:
    Does anyone else have any other cool tricks/mods?
  2. Boodokhan
    Thank you for sharing this information/ trick. I like the idea of being creative and making better headset but I rather have an intact headset rather than a better quality but cosmetically damaged.
  3. Kalach Portable
    Kalach Portable New Member
    Miami Beach, FL
    IUt looks quite good actually. I mean not a half-baked result =) I have the S60 and other ones from the s line. Love them but none of them are actually functional I suspect the belt is the culprit on all of them. I will keep my eyes open for those mods. Anu idea where to find an extra remote for these units?
  4. Command8
    London
    nope, maybe by buying broken s60's. anyway i re-modified the remote and instead changed from earbud to a 2.5mm jack, this allows me to plug in my high quality akg y50's. I was worried there wouldn't be enough power in the remote to power my headphones but i was wrong, works like a charm.
  5. Kalach Portable
    Miami Beach, FL
    That's great but still won't solve the lack-of-remote issue.
  6. Command8
    London
  7. Kalach Portable
    Miami Beach, FL
    Hi! Thanks for the link and your help; unfortunately that one won't work. I already have 17 Panasonic Walkmans and with them a variety of remote controllers with the same compatible plug type, only none of them will work. Perhaps the volume and play button would work but that's about it. Panasonic's S80 remote controller is unique since it is much more complex than any other offering parametric EQ display plus a button to set a variety 0f sound processing settings. Even Sony's remote controller are more compatible among models of the same decade.
  8. vincentv478
    vincentv478 Member
    est
  9. vincentv478
    vincentv478 Member
    est
    Also, I would recommend placing a gob of glue/hot glue on the inside as the crimp sleeve used to hold the cable inside the socket can be hard on the tiny cable.
  10. vincentv478
    vincentv478 Member
    est
    p.s. if you have any intention of selling a s60 or s80 I am greatly interested in acquiring one.
  11. vincentv478
    vincentv478 Member
    est
    Hell, I would even replace the belts free for you if you let me try em out for a week ;), shipping and cost of belts on you though :p
