Perfect Walkman repair mat ??
Discussion in 'I found this!' started by wm_dan, Nov 12, 2017.
  1. wm_dan
    wm_dan Member
    UK Yorkshire
  2. Brandon
    Brandon Member
    Sheffield
    Might get one of those me self
  3. wm_dan
    wm_dan Member
    UK Yorkshire
    Hello fellow northerner!
  4. Deb64
    Deb64 Active Member
    Leicestershire, England
    I've just written a note on the other forum about this. Having worked in electronics for many years, I cannot recommend it for repairing any circuit board which contains semiconductors and ICs which may be static sensitive (i.e, all of them), especially those which cannot be replaced.
  5. Brandon
    Brandon Member
    Sheffield
    Ayup
    wm_dan likes this.
  6. Brandon
    Brandon Member
    Sheffield
    Good shout , Thanks for that.
  7. Boodokhan
    I do not think this is a good one for walkmans, it is small and you need a bigger working space .
  8. wm_dan
    wm_dan Member
    UK Yorkshire
    Mine should be here tomorrow or Wednesday, and I am actually in the middle of a DD33 repair, so will take some pictures and report back asap.
  9. wm_dan
    wm_dan Member
    UK Yorkshire
  10. T-ster
    What do you think of it so far?
  11. wm_dan
    wm_dan Member
    UK Yorkshire
    perfect for walkmans
    for tape deck transport servicing i think it will quickly get cramped
    ill let you all know asap if i ever fry a walkman using the non esd grounded mat
  12. Brandon
    Brandon Member
    Sheffield
    I'm going to get one , only last night I had a ex 615 in bits at my desk with the screws in a plastic box which I inadvertently knocked over and lost the screws (for now) .
    Maybe good for clumsy people like me.
    That thing is awesome, I have to get one! DEB64, I couldn't find your thread, what is the static issue? Can I ground it or modify so there's no static?
  14. Deb64
    Deb64 Active Member
    I wrote here my reasons why I would not use it for Walkman repairs.
    It is sold for repairing smartphones and similar devices but the components used in modern smartphones are a lot more prone to static damage due to the greater component density and miniaturisation so I do not think it is suitable for the purpose for which it is intended.
    Since it is made of insulated plastic, I cannot see how it could be modified to make it ESD safe.
    There are lot of things I like about it, such as separate boxes with magnetic bases for all the different screws and bits. An "ESD safe" version, made from conductive plastic with a 10mm stud in one of the back corners, to connect an earthing strap, would be a very good product.
