I found a perfect replacement for rewind reel-gear. http://kkpmo.istore.pl/en/gearwheel-m-0-3-d2-0mmt3-0mmw6-6mm-20-teeth-black-polyacetal.html
Nice! I wounder it that can be used in a D3, with a pulley glued on top for the counter belt - i bet the old pulley can be cut off from old broken d3 gear and be put onto this one
It's excellent find. Fortunately it is simple gear. In wm-d3 the situation is little different but it should not be big problem to make pulley part only and attach it to the top of small gear.
just need a small 2mm pulley on top of that new gear some thing like this http://www.ebay.co.uk/itm/50Pcs-Pla...162878&hash=item2a8cdd7d41:g:fdoAAOSw6NhZsQV9 I think this could be the savour of many D3's
Hi! I was just curious if you had any luck with the rewind gear replacement, or if you found some other alternative. My WM-DD33 needs a new gear, I tried gluing the old one, but can't get it to mesh properly with the other gear.
Yes, exactly that gear. From reading the thread, I wasn't sure if anyone had actually tried it yet in a Sony DD, or if it was something that could potentially work. Were you successful in fitting it? Sorry for being a bit slow here.
