Trying to repair a WM-D3 (TC-D3 in UK)
Discussion in 'Tech talk' started by wm_dan, Sep 21, 2017.
  1. wm_dan
    wm_dan Member
    UK Yorkshire
    Hi guys
    I won this on eBay for £17. It was advertised as not working. Mainly because it was in pause..
    It did play a tape and sound great, but Rewind didn't work, but then after 10 mins it chewed up a tape. Not sure if that was anything to do with the rewind gear crack or just a dirty pinch roller.
    So it needs a new DD gear which I've ordered, it also needs a counter belt which i've also ordered.
    The door needs a good slam to stay closed, I think I can fix this
    The rewind gear - which also drives the counter - has cracked, because it's cracked it expanded and won't mesh properly with it's drive gear.
    It was getting stuck.
    I removed it and super glued it really carefully (without the shaft in place so it shrunk back to its correct size) but I think the glue has still expanded it slightly and it still stuggles to mesh when trying to move the gear with the bigger gear using a light touch it gets stuck..
    At this stage I think this may be a right off but ill have to let you know when its back together
    I've repaired a DD before but not a recording one. This once was a really PIA due to the extra record mechanism parts in the way.
    I guess if it does end up a right off I will still have a new DD gear for next time I find a cheap one.
    Here are some pictures.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Wish me luck !
  2. Helaba
    Helaba Active Member
    Belgium
    Very good luck!!
    wm_dan likes this.
  3. doublecee
    doublecee Active Member
    Earth
    Yeah, may the force be with you on that one.....
  4. 16s
    16s Member
    Just don't open your windows when it's windy outside otherwise it's gonna be a super guessing game
  5. wm_dan
    wm_dan Member
    UK Yorkshire
    Haha since moved everything and re labeled everything whilst waiting for spares
  6. Command8
    Command8 Active Member
    London
    I'd advise putting any small parts/screws in empty ice trays, it's what I usually do.
  7. wm_dan
    wm_dan Member
    UK Yorkshire
    With help of another member, I managed to get a tiny rewind gear that meshes correctly and doesn't jam but it's still cracked
    I've ordered a 2.05 drill to help remove the stress of the metal shaft
    Not really sure what glue to use, super glue seemed pretty useless on nylon
  8. jacobsteel
    jacobsteel New Member
    Gothenburg, Sweden
    nice pictures! thank you --- and best of luck! keep us posted.
    As for tiny screws, I bought a cheap magnet board on Ebay (one of those with a grid on them), works nicely and the magnet holds tiny screws in place.
  9. Will
    Will New Member
    Netherlands
    Great pictures! Thank you. This'll save me a lot of time reassembling my D3.
    Your obviousy putting a lot of Love in this repair. :D
  10. T-ster
    Yeah even if this doesn't work you have documented a process which may help hundreds of people down the line :thumbup:
  11. wm_dan
    wm_dan Member
    UK Yorkshire
    Thanks so much for the encouragement, it really does help.........
    Today I made a bit more progress regarding the rewind gear
    I must thank forum members; mihokm, TooCool4 and A.N.T for help and advise.. I am not an electronics engineer or a mechanical engineer, so without their help this walkman would most definitely end up a paper weight
    I had to make a plastic ring with 3.4 mm hole.. to re-inforce the gear.
    Just by pot luck I found some almost perfect rings in old Technics cd player mechanisms.
    Still waiting for a 2.05mm drill bit, But with the plastic ring in place and the shaft only pushed in 2-3mm for testing, the gear no longer jams :D :D
    I was kindly sent a spare mechanism by TooCool4, but it then became obivous someone has been inside my D3 before... So I am still not out of the woods yet
    If anyone would like me to make and send them the plastic ring with the 3.4mm hole I can do this and send to you free of charge.
    [​IMG] [​IMG]
    16s likes this.
  12. wm_dan
    wm_dan Member
    UK Yorkshire
    UPDATE:
    Here I have pics and video of working mechanism.
    I am still waiting for a 2.05 mm drill bit to finish the rewind gear repair
    This is with a semi-repaired REWIND gear, 95% ok, but will repair my other spare ASAP, that repair should be 100% ok
    So I am confident the mechanism is actually ok, despite been previously tinkered with.
    However the circuit board has been folded and unfolded away from the mechanism about 10 times now. So I am worried I've possibly broken a wire. Will only know onces the board is screwed back down. I think I can probably find and fix a broken wire, if its broken at all.
    ALSO - Anyone who can get that tiny spring (on the black lever which lifts the head and roller) by themselves should be a brain surgeon! Same with washer part number 114 (d3 record mech only!) My GF had to help me as I needed 3 hands!
    [​IMG] [​IMG]
    Even if my walkman has other electrical issues and can no longer be used I hope my post will help other people as I have received plenty of help and advise myself
    Regards
  13. Command8
    London
    Wow that is some impressive work.
    Waaaaaaaaaaaaaayyyyyyyy beyond my capabilities... I can only hope to attain your skill level
    I salute you (0_0)7
  14. wm_dan
    wm_dan Member
    UK Yorkshire
    Thank you but I cannot accept your kind words because I followed guides and advise mainly from Marian - the man is a genius
  15. wm_dan
    wm_dan Member
    UK Yorkshire
    So the D3 is now back together and appears to be working 100%. I have played both sides of a 90 min tape without any issues at all.
    It even records really well. It's obviously not as good as my D6C on recording or Playback but, I have a DD33, and really wouldn't say there is any difference on playback... but I heard the DD33 is not even high end.
    Anyway I digress... Tips for anyone taking apart a D3...
    Put some sticky tape over the pause button and the VU/Battery switch !!! Because these plastic switches slide about with 0 pressure, I almost snapped my VU switch off :(
    Usual tips, take your time and do not force anything
    Read Marians DD gear repair and preventive maintenance on here
    Here is a vid of it. The rewind and FF are sometimes squeaky - but so is my DD33 is also the same (ONLY WITH A TAPE IN)
    freesofia, Command8 and 16s like this.
  16. 16s
    16s Member
    1984:thumbsup:
  17. wm_dan
    wm_dan Member
    UK Yorkshire
    The door closing issue was solved by
    1. Stretch the door latch spring a bit to tighten the catch
    2. The door actually needs bending in slightly at the bottom where it folds over 90 degrees. I taped up the bottom side where the 2 screws are to protect it
    Then got an adjustable spanner and very carefully and slightly bent it in the bottom smallest part so it is now a smaller angle then 90 degrees
    My door closes and holds good with or without a cassette inside
  18. mihokm
    mihokm Active Member
    Slovakia
    Excellent work.
    I still need to update manual with WM-D3 specific instructions. It's plan for version 2.
    Does anyone know why this door closing issue happens so often with D3?
  19. wm_dan
    wm_dan Member
    UK Yorkshire
    it probably just gets strained from been open and closed a lot
  20. wm_dan
    wm_dan Member
    UK Yorkshire
    Note to self... if a screw previously had loctite on it from Sony.... Re-apply god damn new loctite!!! level 10 n00b error!!
    My take up real gear came loose!!
