Broken Switch
Discussion in 'Tech talk' started by mihokm, Feb 12, 2022.
  1. mihokm
    mihokm Active Member
    Slovakia
    After a while, I am back to walkman repair. I am working on DD33 and previous owner broke megabass switch pin, as he tried to assemble it.
    This is very small switch but I was able to fix it. Now it is stronger than original. I drilled 0.5 mm hole to the center of the slider, which is 0.8 mm thick. I made new 0.5/1.2 mm pin on lathe and inserted it to the slider.
    I was inspired by my dentist :)
    Raul, Kili1234, RTB and 1 other person like this.
  2. Shaman32
    Shaman32 Member
    Greetings Marian, I agree with you, Dentists use similar techniques,,,
