Mihokm Center Gear scrapeing on center arm
Discussion in 'Chat Area' started by David Piçarra, Feb 21, 2020.
  1. David Piçarra
    David Piçarra Member
    Portugal
    Hello everyone I installed the gear from Marian and while it works okay I can hear a rumble during use
    Seems like one of the screws are scrapeing on the center arm that holds the gear disc
    Any ideas?
    I tried to tighten the screws in a way they are the flatest
    Maybe it's a defect ?
    Thanks
    Costa32 likes this.
  2. Boodokhan
    I have installed many central gears from Marian, probably more than 30. None of them have a problem. I am not questioning your installation Technics but this should be a delicate work. Try to reinstall them again. Also run the motor while the gear installed and record a video to show where the noise is coming from. I am sure this can be fixed. During removal of old plastic gear mistakes can happen by applying pressure to the axle. The angle between the axle and the disk should be maintained same, If by mistake this angle is changed it will create some type of noise/grinding sound while motor moving. I have done this mistake and experienced this problem.
    By the way, @mihokm is very supportive on products he sells. Try to contact him and he will take care of it
    Costa32 likes this.
  3. David Piçarra
    Portugal
    I managed to fix it,by slightly sanding the screws,altough when i have my DD3 on Rewind it always makes a screetching noise:thinking:
    Costa32 likes this.
