Mixtape Time Calculator
Discussion in 'Cassettes' started by AlbySpace, Jun 8, 2018.
  1. AlbySpace
    AlbySpace Member
    Italy
    I just put togheter a simple way to calculate the time of a tracklist via an excel spreadsheet.
    You still have to input titles and duration of each song (even if with some exporting tricks you could retrieve those info from itunes) and then it's just a matter to choose the side (A or B) and the spreadsheet gives back the sum of both sides.
    I also added a "skip" time, if you want to add a few seconds in between each track. That can also be left at zero.
    Hope you like it!
    https://www.dropbox.com/s/gcu3e7i6jr6aer4/Mixtape #1.xlsx?dl=0
    stuck-in-time and ciclosysombras like this.
  2. ciclosysombras
    ciclosysombras Member
    Alicante, Murcia, EspaƱa
    Thanks for your contribuciĆ³n at the time of making mixtapes and calculate the correct time and no waste the empty tape space ;)
    AlbySpace likes this.
  3. stuck-in-time
    Jakarta, Indonesia
    Now I'm tempted to also make an excel that lets you list a bunch of tracks & durations and automatically make a playlist tailored to a specific cassette length. Making the most use of each side with minimal waste (of course, at the expense of mixing up the track order) :hmmm
  4. AlbySpace
    AlbySpace Member
    Italy
    Yes, I thought about that. i think it would require some macro wizardry, but my skills in excel don't go as far as that :)
    My next goal would be to make an automated Jcard from the tracklist in the same file.
    stuck-in-time likes this.
  5. AlbySpace
    AlbySpace Member
    Italy
    I updated the file, you can find it here:
    https://www.dropbox.com/s/gcu3e7i6jr6aer4/Mixtape Creator.xlsx?dl=0
    It now has the ability to plot the entire playlist, side by side, on the L-card (not adjusted the size on the J-card yet), as long as you print without scaling in an A4 sheet.
    You still have to manually order the tracks (via filters in the # column)
    I also added a password which can be found in the following "captcha"
    Hope you like it guys!
    ciclosysombras likes this.
  6. PULOVR
    PULOVR Member
    Canada
    I've been using this for as long as I can remember. It's simple to use and is always with you if you have a smart phone or tablet.
    iOS version.
    https://itunes.apple.com/ca/app/mixtape-calculator/id1087031743?mt=8
    Android version.
    https://play.google.com/store/apps/details?id=com.wildbeep.mixtapecalculator&hl=en_CA
    There are also a variety of "Cassette Player" apps out there that will display a realistic cassette tape while your song lists are playing (complete with spinning tape reels).
    Some examples.
    https://tinyurl.com/ybwq9fh5
    The tapes available in the various apps look like the real ones but with some small changes because of copyright, but I believe one or two of the apps allow you to also purchase additional cassette "packs" that have regular tapes without the copyright issues. Either way it looks cool while it's "playing".
    I found out about the iOS tape calculator and tape player apps one Halloween after Guardians of the Galaxy was released. Someone made a realistic looking TPS-L2 prop with their smart phone. They said the real one was way to expensive so they made a painted cardboard version. It looked pretty good imo.
  7. walkman archive
    Thanks for the file. I was also using Excel since some months and it's very useful.
