My thoughts on Marian's DD gear...
Discussion in 'Tech talk' started by doublecee, Nov 19, 2017.
  1. doublecee
    doublecee Active Member
    Earth
    Sublime!
    Marian recently returned a Batch of DD units to me, ranging from a D3, a few DC-2's and my prized MINT DD-100.
    Each one is an absolute gem, and any memory of a prior fault is totally erased.... in fact, the new gear and subsequent service has rendered each machine as BETTER than new... A bold statement? No.... Its just a very simple fact.
    Im currently enjoying some Studio One Reggae on my D3 and I dont think its ever sounded so good since it was given to me in 1987 as a present. It runs so smoothly, and sounds so sweet! As a 17 year old I knew this machine was special, but now it just sounds amazing...
    Same with the DC2's and DD-100. All amazing, as to be expected from those models.... but the D3 has been elevated to Hero status, thanks to Marian. The D3 has incredible sentimental value to me, so it was always very important to get this one working again....
    Top Job. Take a bow, Marian.
    enryfox, 16s and Ball000 like this.
  2. wm_dan
    wm_dan Member
    UK Yorkshire
    I've fixed a several dd walkmans now with Marians DD gear and capstan ring
    All have performed bang on factory specs or in some cases actually better (0.06%wrms w+f)
    Every time I see that white gear I think hundreds, if not thousands of hours must have gone into designing, researching and making it. It's very hard to find companies who want anything to do with stuff like this
    I know other people repair the old gear but to me Marian is the true saviour of Walkmans, his guide enables n00bs at home, like me, to still do a good repair
    My only regret now is not buying lots of DD walkmans a few years ago when they were £20-£30 !!
    Ball000 likes this.
  3. buzbox
    buzbox Active Member
    Australia
    I was a noob when it came to DD's. But after getting a few DD's and trying to repair the gears I was successful only once. The gear kit that Marian provides is the only way to fix them now. One happy customer here!! :)
    wm_dan likes this.
  4. wm_dan
    wm_dan Member
    UK Yorkshire
    I just bought another gear tonight :)
  5. wm_dan
    wm_dan Member
    UK Yorkshire
  6. Command8
    Command8 Active Member
    London
    Wish I knew a guide existed before I butchered my repair job...
  7. wm_dan
    wm_dan Member
    UK Yorkshire
    you havn't
    start again and go through all the guide. also service manual shows you height alignment for the gear
  8. mihokm
    mihokm Active Member
    Slovakia
    Thank you very much, I'm really happy that I can share my hobby with so many good people,
    I like challenges and I always like to work on something new. Behind each part, there's lot of study regarding materials, properties, etc.
    DD center gears sell little better than I expected. That's why I'm able to finance development of other spare parts.
    Currently I'm working on
    - pinch rollers for narrow Sony walkmans (rubber plus core)
    - capstan ring for WM-DD9
    - idler tire for WM-55 series
    - pinch roller dor D6C, DD....
    - capstan ring for DX100
    - small idler tire for D6C and TPS-L2
    - small reel gear for WM-D3
    - pinch rollers for Panasonic RQ-S/ RQ-SX
    plus I'm preparing rubber kit for TC-D5M.
    They should all be ready by the end of 2018
    And I'm working on e-shop. I would like to offer not only belts and rubber parts, but also small capacitors, tools, oil, etc.
    Any profit will always go to development of another parts.
    If you have any idea, what else could be produced, just let me know.
    AlbySpace, Pierre, T-ster and 5 others like this.
  9. enryfox
    enryfox Active Member
    close to Milan (Italy)
    I'm looking forward to be able to buy high quality small capacitors from a trusted source: I would like to recap myself some faulty units, but I'm not sure where to buy good quality capacitors of the correct size for use in walkman's. Besides, I do not want to have to buy batches of 100+ caps when I need just a couple of each value.
    As for spare parts I would like some replica of the fragile gears of the WM-EX49 tape transport used also in several derivatives: they are all really nice looking but that mechanic has several weak points and it s very hard to find one in working conditions.
    AlbySpace likes this.
  10. wm_dan
    wm_dan Member
    UK Yorkshire
    E shop is a really good idea, Then you can ditch eBay and their high fees
  11. mihokm
    Slovakia
    I was thinking of making parts for WM-EX49 like mechanics. But this mechanics has so many issues. Several cracked gears, deformed plastic parts... and most have leaked capacitors. What a pity. Optical design of these is very nice. And also sound quality is good.
    I don't think it is cheaply built. It is full of tiny, difficult to make, plastic parts. Just very unreliable design. But one day, may be...
  12. bub
    bub Active Member
    Singapore
    For now you can buy caps from mouser, Farnell, or Newark (I buy from Newark element 14.) The caps themselves are very cheap but the shipping is usually the expensive bit. Use this list for Walkman caps: http://www.stereo2go.com/forums/threads/list-of-common-walkman-capacitors-2017.1246/
    I would love reproduction WM-150/EX-49 gears. The weak points are the tiny clutch gear and the takeup reel gear. Current workarounds are to weld the clutch gear together, and for the takeup, sacrifice a supply gear from a parts unit (same diameter) and grind it down to the thickness of the takeup gear and sub it in.
    Otherwise they are good mechanisms with EX amorphous heads, and nice design like WM 150,550C,EX49.
    Another mechanism to consider with weak gears is the late Panasonic EX series clutch and cheese gear.
