Original charger for AIWA PB-4 batteries?
Discussion in 'Tech talk' started by Fulltimehuman, Dec 7, 2024.
  1. Fulltimehuman
    Fulltimehuman Member
    Bremen, Germany
    Does anyone know what would have been the original charging solution for Walkmans that used AIWA PB-4 rechargeable batteries (for instance in an HS PX410)? I was unable to locate the proper user manual or identify a charger type provided by AIWA)
    Thanks!
  2. Cassette2go
    Don't know what kind of battery that is without searching the internet so I'll just say this. I charge my gum stick batteries this way in a Nightcore Multi-Voltage multi battery charger 17336002311935335946024685569257.jpg
  3. Fulltimehuman
    Bremen, Germany
    Doesn't' work for AIWAs. Those are irregular gumsticks with both poles on one side.
    Cassette2go likes this.
  4. Cassette2go
    Well then I suggest you get your handy dandy jumper cables and make a battery compartment charging thing and make it work. That's what I've been doing is making things work. I just found this spring that I can use on my little flywheel here that needs a spring here. I'll put that close to that and take a picture 17336006362803567640359287071731.jpg
    DutchNick and Hyperscope like this.
