Panasonic RQ-NX10 (SERVICED) + Accesories Panasonic + Panasonic Speakers
Discussion in 'Stereo2Go classifieds (not auctions)' started by krzysztofm30, Nov 1, 2023.
  1. krzysztofm30
    krzysztofm30 Member
    Poland
    PANASONIC
    MODEL: RQ-NX10
    MANUFACTURER: PANASONIC CORPORATION (MATSUSHITA ELECTRIC INDUSTRIAL CO., LTD. JAPAN)
    YEAR OF PRODUCTION: 1999
    PLACE OF PRODUCTION: TAIWAN (MADE IN TAIWAN)
    ADDITIONALLY INCLUDED:
    1. ORIGINAL, FACTORY DEDICATED PANASONIC HEADPHONES MODEL: RFEV326P-KS.;
    2. ORIGINAL, FACTORY DEDICATED PANASONIC REMOTE CONTROL MODEL: RFEV012P-KS. THE REMOTE SUPPORTS ALL PLAYBACK FUNCTIONS: (PLAY/STOP/SCROLL FORWARD/BACK/HOLD/VOLUME ADJUSTMENT).;
    3. FULL FOLLOW-OUT AND ILLUSTRATED WALKMAN USER'S MANUAL (1:1 SCALE COPY). INSTRUCTIONS IN 11 LANGUAGES, INCLUDING POLISH AND ENGLISH. THE MANUAL CONTAINS RULES FOR USING THE DEVICE, AS WELL AS TECHNICAL DATA AND MAINTENANCE METHODS;
    4. PANASONIC LIMITED WORLDWIDE WARRANTY CARD IN ENGLISH;
    5. INSTRUCTION CARD ON HOW TO PLACE THE CASSETTE INSIDE THE DEVICE (COPY ON A 1:1 SCALE).;
    6. 8 NEW PANASONIC 1.5V AA ALKALINE BATTERIES (ADVANCED LONG LASTING ENERGY). 4 BATTERIES ARE USED TO POWER THE INCLUDED SPEAKERS, TWO FOR EACH SPEAKER. 4 REMAINING BATTERIES ARE DESIGNED FOR THE WALKMAN, WHICH IS POWERED BY 1 1.5V AA BATTERY;
    7. ORIGINAL BOX (RPKT0223) FOR WALKMAN AND SET. MINOR, LOW VISIBLE SIGNS OF USE, COMPLETE;
    8. TWO ACTIVE STEREOPHONE SPEAKERS (ACTIVE SPEAKER SYSTEM) PANASONIC MODEL: RP-SP50. MANUFACTURED IN 1991 IN KOREA (MADE IN KOREA).;
    9. CONNECTING CABLE FOR THE SPEAKERS, WHICH CAN CONNECT THEM TO THE WALKMAN.
    VISUAL CONDITION: PERFECT. Metal (aluminum) housing. Minimal signs of use in the form of a few practically invisible scratches. Perfectly preserved color and gloss of the housing. No cracks, breaks or chips. Perfectly preserved markings/inscriptions, not worn out. The "Panasonic" groove looks great on the housing. The inside of the Walkman (the so-called "pocket") is in factory condition. The battery compartment is clean, free of rust, moisture and other deposits. Original battery cover in perfect condition, tightly closing the battery compartment, which contains the device's serial number, fully legible. Perfectly preserved, in new condition, switches, volume knob, headphone output. Similarly, the cassette compartment opening system. Exceptionally very good visual condition of the walkman, close to new/like new, especially considering the age of the device (23 years old). Excellent workmanship and interesting design, once very modern, now referred to as retro/vintage. The speakers are in good visual condition and show minor signs of use. No cracks, breaks, chips or drastic scratches.
    TECHNICAL CONDITION: PERFECT (LIKE NEW/SERVICED). Audio cassette playback is fully operational and works flawlessly. All functions, knob switches and buttons related to playback and scrolling are active. A fully functioning AUTO REVERSE system for "flipping" one side of the cassette to the other side. The sound is exceptionally strong, clean and dynamic, which can be modulated by boosting the bass/bass tones (S-XBS SUPER XTRA BASS SYSTEM). All functions of the Walkman have been thoroughly and thoroughly checked before being put up for auction. They can be used, also via the remote control, with headphones. Both the remote control and headphones have been checked and work perfectly without any interference. Thanks to the included active, stereo Panasonic Active Speaker System speakers, model: RP-SP50, you can use the player as a stationary HI-FI set. Speakers tested, fully functional, no defects. Clean and dynamic sound, characteristic of active stereo speakers (Active Speaker System). Impedance 8 Ohms.
    The device has been professionally and precisely serviced. The playback drive belt was replaced with a new one, which was purchased abroad in a store that professionally selects replacement drive belts for cassette players, perfectly matched in technical terms and properties to the original one. The drive and mechanism of the Walkman were functional before replacement, but required thorough and precise maintenance and cleaning. When replacing the belts, the internal parts and components (motherboard, battery contacts, headphone output, etc.) were carefully cleaned with professional electronics preparations. A specialized cassette tape was used to clean the head and tape feed system. The relevant parts of the mechanism that required it were improved by applying specialized grease. Also a system for opening and closing the cassette compartment. Careful servicing will definitely extend the operation of your Walkman. Its cost is included in the price of a Walkman. I guarantee that the Walkman will function properly.
    FUNCTIONS (EXCEPT THE BASIC FUNCTIONS: SCROLL FORWARD/BACKWARD, PLAY, STOP):
    1. NORM/METAL SWITCH. A system that adapts the operation of the Walkman to normal and metal (chrome-plated) cassette tapes;
    2. S-XBS (SUPER EXTRA BASS SYSTEM). System for boosting low bass tones/changing the sound tone. The system allows you to give the sound the appropriate "depth";
    3. AUTO REVERSE SYSTEM. The system is based on the PLAY button, which allows you to switch the playback page at any time. The function is also active when tape playback ends.;
    4. TAPE PROGRAM SYSTEM. Search for the beginning of a recording. A function that allows you to skip up to 3 songs by pressing the PLAY button or the appropriate button on the remote control;
    5. HOLD FUNCTION. Key lock.;
    6. CLOSING THE CASSETTE FRAME COVER. Prevents the Walkman from being accidentally opened.;
    7. NOISE REDUCTION SYSTEM (DOLBY NO.);
    8. BATT CHECK. 3-STAGE BATTERY CHARGING LEVEL INDICATION SYSTEM, BASED ON A SEPARATE BUTTON AND 3 RED LEDS.
    POWER SUPPLY: 1 X AA BATTERIES 1.5 V (SO-called "FINGER"). INCLUDES 8 NEW PANASONIC 1.5V AA ALKALINE BATTERIES (ADVANCED LONG LASTING ENERGY).
    I WILL PROVIDE SHIPPING IN SAFE PACKAGING. SHIPMENT (EU) INCLUDED.
    OTHER COUNTRIES - PLEASE CONTACT
    PRICE: 270 EURO
    IMG20221214123617.jpg IMG20221214123700.jpg IMG20221214123728.jpg IMG20221214123814.jpg
    IMG20221214123134.jpg IMG20221214123617.jpg IMG20221214123700.jpg IMG20221214123728.jpg IMG20221214123814.jpg
    Helabaa and Boodokhan like this.
