Restoration : Acrylic Windows - polishing
Discussion in 'Tech talk' started by mankamaz, Dec 3, 2016.
  1. mankamaz
    madrid,. spain
    Originally posted by:
    DOCP
    Whether it is your tuner windows on boomboxes or the cassette windows in walkmans there is nothing as pleasing and satisfying as a crystal clear finish instead of the nastily scratched appearance that is most usually seen on account of years of use, misuse and abuse by the time it lands on ebay or in the dumpster.
    1. Cleaning : Household detergent is fine, Kerosene to remove greasy deposits is quite okay but with anything that is a solvent try wiping off the residue immediately and go back again to a detergent wipe. Some alcohols make the acrylic surface go opaque and this can be quite scary/disappointing although it can be reversed by subsequent buffing it it is just the surface! So be a bit careful on this note.
    2. Removal of deep scratches : Removal of deep scratched will require careful sanding out of the scratch by manually cancelling out the scratch. This involves removing a bit of the surface so that the defective area is smoothed out by way of abrading the surface in opposing directions/a circular manner. of Water emery paper is available in the following grits :
    a)fine (P120), b)very fine(P220 or P360) c)Extra fine (P600) d)Super Fine (P1200) & Ultra Fine (P2500)
    The secret to using emery the right way is PATIENCE and controlled pressure...extremely light pressure/almost a feather touch for the Fine(P120) grit as you are effectively creating new scratches at 90 degrees to remove the original scratch. It is important to make sure you have a drop of water and that the process is always being done 'wet' to prevent 'surface burns' . The water lubricates the surface allowing for better control with the circular motions of initial abrading. Progress slowly through the finer grits each time using only a small piece of emery paper (approx 1 sq.inch) thus forcing you to use more control and also preventing the edges of the emery from damaging surfaces adjacent to the window if it hasn't been removed.
  2. mankamaz
    madrid,. spain
    3. Polishing : Abrasion done with a much finer grit or much less pressure is the precursor of the polishing process. After finishing a run through with the Ultra Fine (P2500) emery paper I would advise a shift over to polishing paste (better than polishing cakes/compound). A few examples :
    http://www.audioadvisor.com/pr....asp?number=CLACRPOL
    http://www.theplasticshop.co.u...-xerapol-3373-0.html
    I normally go with CIF scouring cream or 3M Finesse it followed by toothpaste [​IMG]followed by Formula1 Scratch out
    http://systemhygiene.co.uk/pro...am-2ltr-product.html
    http://www.formula1wax.com/pro...scratchOutLiquid.php
    Soft cotton cloth (an old T shirt/Vest) [​IMG] will serve as a decent enough buff cloth for the manual stage of buffing. It is again important to try and keep your hand motions circular. If you want to go 'professional' a piece of Chamois leather will be quite fine although I'd stick with the cotton cloth.
    4. High Shine /Gloss : Achieving a mirror shine or Gloss actually requires 'micro melting' the surface of acrylic. Although some industrial processing employ flame polishing I wouldn't recommend this approach at all. What you need is to generate enough heat at the surface to just make a microscopic layer melt and re-solidify as a single glaze layer.
    This either requires a polishing lathe like what we dentists have and use for polishing dentures or a hand held polisher like what is used to buff up your Car's paint job although this tool is a bit cumbersome and big. The best is a Dremel drill (again similar to a dental laboratory drill [​IMG]) with miniature buff wheels (like the stuff we dentists use [​IMG]) :
    Cotton yarn /muslin cloth/cotton cloth buff wheels
    http://www.rutinident.com/lab-...shes-handpiece-buffs
    ebay 390385448740 ,140877083421
    A Dremel 7000-N/5 6-Volt Cordless handpiece/hobby drill should cost approx $25 on amazon.com.
  3. mankamaz
    madrid,. spain
  4. mankamaz
    madrid,. spain
    One lousy example is window damage due to 'prolonged storage' in warmer climates like what we have...you end up with the walkman pouch rexine's inner surface melt-imprinting in a pitted pattern corresponding to the inner 'cloth' surface
    These pits are approximately a quarter millimeter deep if not deeper....the equivalent of a pretty deep scratch.
    So here are a few before and after pics for you to have a rough idea [​IMG]
    MART - GF9292 likes this.
