Saisho PS50
Discussion in 'Gear you want' started by Darren, Nov 20, 2018.
  1. Darren
    Darren Member
    Leicestershire
    Its a long shot, but am after a working Saisho PS50 or can anyone suggest someone who could fix my own one.
    It doesn't power up using batteries or mains plug. Am in Leicester, uk. Top money for the right one.
  2. Longman
  3. Darren
    Darren Member
    Leicestershire
    Thanks for the link Longman.
    I didn't know it was Dixons brand, trouble is finding one.
    I rarely have units that are 100% dead unless the batteries leaked and ate everything or someone dropped it. I'd pull the back cover and see if any of the wires around the battery compartment or jack are disconnected. Since neither of those work it might also be the tape/radio switch (or wires).
    The first thing I do is spin the batteries in the compartment with the radio on, see if the light flickers. If that doesn't do anything then make sure you have the right size power jack and that the +/- is correct. I use a Radio Shack Wall Wart Power Supply with detachable tips that I can change polarity because most units will not work with reversed polarity. Make sure the inside contacts don't have a lot of dirt or corrosion and the plug touches everything, move it around and see if any lights flicker.
    I bought a lot of Casio Keyboards for cheap because they use the opposite polarity as 95% of other consumer electronics. Unless your using a Casio Wall Wart or a universal power supply with selectable polarity, these units may seem "dead".
  5. Darren
    Darren Member
    Leicestershire
    Thanks for that, I will try taking it apart later when am not working. I have tried a multi jack and multi power range plug that I have tried but no luck.
    Like you say it could be a loose wire. I will keep you posted.
  6. Darren
    Darren Member
    Leicestershire
    Well that hasn't gone to plan, I have tried to open it to have a look inside but its not going good. Many tiny screws holding to many different parts together.
    I just don't know a simpler way just to open the case.
