Sanyo C15 radio issue: Help needed!
Discussion in 'Tech talk' started by Mistew, Oct 25, 2022.
  1. Mistew
    Mistew New Member
    Finland
    Hey, thanks for tuning in to this thread! :)
    A little time ago I repaired this old Sanyo C15 boombox, the cassette player was not working on it.
    I got the cassette player working but recently I found out that (I think at least), that the radio is not working correctly. It doesn't receive channels as it should. Upper up the FM band it receives a few channels but lower down none. I found out an odd thing about it, when you push the tuner selector button upwards in a specific position it receives the channels just as they should. Sometimes the trick works, sometimes not.
    Does anyone here know anything about what may be causing the problem and/or how I could possibly fix it?
    I'm not at all myself familiar how to fix the radio part of a boombox and thus I have no clue what is going on.
    Is this something I could fix myself? Should I take a look inside? (If so, what should I look for?)
    I've provided a short demonstration in video form here, linked to the thread. I hope it may help a little! :)
    Kindest regards, Nipo.
    I'd probably start with DeOxit or Faderlube or a similar contact cleaner. You guys over there might have different brands.
    It needs to get to the sliding metal parts inside of that switch so you might have to take the unit apart. Old member Arkay wrote some advice on another forum with tons of other members chiming in.
    https://audiokarma.org/forums/index.php?threads/the-idiots-guide-to-using-deoxit-revisited.207005/
    Also look over any wiring going to the switch, any part that gets a lot of movement might need resoldering.
    DutchNick likes this.
  3. Mistew
    Mistew New Member
    Finland
    Alright! Thank you for the advice! I'll look into it:)
  4. Mistew
    Mistew New Member
    Finland
    Well, I finally got it to work. Thank you for the advice again!
