Strange film over the heads - treble loss
Discussion in 'Cassette Decks' started by ciclosysombras, Dec 17, 2018.
  1. ciclosysombras
    ciclosysombras Member
    Alicante, Murcia, España
    Did anyone have this problem? A strange film covers the play / record heads causing treble loss. I was try to remove this with isopropilic alcohol without results.
    What i need to remove this? Can i try with a electronic contacts spray cleaner?
    Greetings!
  2. Reli
    Reli Well-Known Member
    I have used a pencil eraser before, but you need to be gentle with it.
    ciclosysombras likes this.
  3. Kahenraz
    Kahenraz New Member
    You might want to try a damp magic eraser. I think you would have more control with that than a pencil eraser.
  4. ciclosysombras
    The problem was solved with the zero residue circuit contact cleaner. Thank you very much to all, but is less agressive than pencil eraser. Greetings!
