WM-F501 Dolby bass switch unit
Discussion in 'Tech talk' started by AMoonRabbit, Nov 20, 2022.
  1. AMoonRabbit
    AMoonRabbit New Member
    Hi all. Finally got time to properly look into the Dolby bass switch on my F501 and have determined that I need to replace the switch completely. The difficult part is that this seems impossible to come across short of buying a second F501. Is it possible to source the part separately or am I out of luck?
    Separately you're pretty much out of luck. While not impossible, it's more likely to find a spare board than such a switch.
    You will need either another F501 or a donor that uses the same switch.
    You can look the part number in the service manual and compare with similar models.
