Sony PS-F5
I have recently bought at my own risk a Sony PS-F5 Linear Drive Turntable . It is not working properly . The needle keeps bouncing off the disc  and the speed might be a going to fast as well Has Anyone any thoughts how to repair it or would be willing to repair it philip
PGTaylor
Original Post
Congratulations on finding (an affording) a PS-F5. Until I googled the model number I assumed you were talking about a more conventional deck.
Anyway ALL record decks rely on a decent stylus so that may be the cause of the skipping. Many people would say to change the stylus as a matter of course if you have doubts as a skipping deck could also be damaging your records. I found a discussion on PS-F5 styluses here:
http://www.vintage-radio.net/f...owthread.php?t=83297
As for speed you could print out a strobe disc to check it but you may have fun using it in a vertical turntable unless you stuck onto a thicker record.
Of course any linear tracker has a whole lot of other things that can go wrong which might be as simple as dried up grease on the mechanism.
Thanks everyone for your help I managed to stop the skipping by simple opening the unit and lifting the stylus slightly which seems to have worked. Very technical I dont think . I presume it got shaken in transit from Spain which was a risk I had to take as the buyer would not guarantee the item  if it were posted I have also managed to get 2 spare styli jut in case  but thanks for the site details about these.
Add Reply
