Walkman Belt reference
My walkman belt request already sent to docP Sharing it again here, should be useful for many I hope.
The WM D3 counter belt shown is not the original but just an approximate size reference. The original one is disintegrated. The correct one is much thinner at 0.7mm. The D6C is around 0.9 mm thick. All others are thin at 0.7 mm. All are old belts, so will definitely be stretched. Maybe add more walkman sizes to the thread as and when you replace yours, if anyone is interested ? atleast the popular ones
HS J 101
HS JX 505
HS PX 101
WM D3
WM D6C
WM EX 80 - (mostly equivalent to wm 701?)
DSC_2322_resize
Thanks
Sushant
The success of a restoration is indirectly proportional to the leftover screws
Photos (1)
Original Post
This is a much awaited thread...thanks for starting it I would advise members to follow these guidelines with caution as final performance without wobbly sound (wow & flutter) requires a balance between the belt size (snug fit) and belt tension ( smart movement without exerting too much force)
wm-10/20/30 10II , F10/20/30/10II, w800, F15/F13 and F65 - 49mm dia 0.7mm thick
DD9 22mm dia 0.9mm thick
Panasonic RQ-SX50V (1998) series: Panasonic RDV0037 Capstan Belt (1) and Panasonic RDV0038 Capstan Belt (2)  24mm and the second one about 32 mm. , 0.7mm
Originally Posted by exchanger:
I have an excel file with belt sizes and my comments about replacement process. I can update the list with information from another users and put a new version to this topic once a month.
A.W.E.S.O.M.E.
Panasonic all RQ-S series and early RQ-SX series: ID64 0.6 mm belt
Panasonic later (by cca. 1995) RQ-SX series: two belts - ID22 and ID30 mm, 0.5 mm thick. Can be used 0.6 mm instead, but do not use 0.7mm or thicker - it has negative effect to the audio quality
Sony WM-EX808 - ID61 mm and 0.6 mm thick
Sony WM-EX/FX909, WM-EX999 - ID28, 0.6 mm
Please, do not use 0.7 mm belts with most Panasonic and Sony models, as the groove in the metal wheels is usually 0.7 mm wide (the same as belt). Better use 0.5 or 0.6 mm, in the worst case 0.8 mm.
Add Reply
