Server problems (disk full, need to upgrade and need donations)
Discussion in 'Announcements and suggestions' started by walkman archive, Sep 22, 2026.
  1. soluna
    soluna Well-Known Member
    My picture view program is Irfan View - that has an easy batch convert function, converting all files, stored in one location from one format to another, and you can adjust different format settings. But would the links then still work, when you have changed the file extensions ?
    Experious likes this.
  2. Experious
    Experious Active Member
    Melbourne
    In theory it should do. If you edit any post with pictures attached you will notice that it refers to an attachment number rather than the file name itself. If that doesn't change it should be good to go and, if that access is available, I am sure we could test it out with one post.
    soluna likes this.
  3. Rune Lindman
    Rune Lindman Active Member
    Sweden
    My donation has been sent. This site invaluable with lots of nice people with common interests and so much useful information.
    walkman archive likes this.
  4. walkman archive
    Thanks Longman!
    Ok, I think you're right. I'll ask the tech how can this be possible, if it is, and see if it's complicated to implement.
    Thanks for the suggestion.
  5. walkman archive
    Thank you guys. I've received several donations and I think with that we can upgrade to a bigger server.
    These days I'm a bit too busy and also a bit lazy to do all these. I could free up a few dozens of MB so I have now probably a few weeks until the problems arise again, and so to do the upgrade.
    I'll keep you updated.
  6. Experious
    Melbourne
    Thanks for all your hard work, Mr walkman archive!
    I was just posting a comment and notices that multi-quote doesn't seem to be working. I can toggle quotes on, but as soon as I try to add them to my post I get this error.
    Just replying to a post adds the quote correctly, which with a bit of editing is how I got my post up.
    I am pretty sure I was not posting anything that was "not acceptable"! ;)
    Edit: Apologies for posting a PNG again! I did try after to convert to JPG, but in this case it only saved 7KB.
  7. soluna
    May be , you can say the machine to save all screenshots as jpg. By my meaning, screenshots only have the function to remind or to point, so quality doesn`t matter so much.
    I compared .jpg screenshots with .png photos that come from google translate. It's the same photo, one is translated and .png. The .png is a smaller file than the original. Just a casual look through my files and .png seems to be the same or smaller files than my .jpg's, nothing is huge but even if it was I'd have to convert it into a smaller files otherwise the uploader would reject it.
  9. Experious
    Melbourne
    There are two thing here. One is that JPG is designed for photography, so is better for pictures.
    "The JPEG (Joint Photographic Experts Group) format can produce a smaller file than PNG for photographic (and photo-like) images, since JPEG uses a lossy encoding method specifically designed for photographic image data, which is typically dominated by soft, low-contrast transitions, and an amount of noise or similar irregular structures. Using PNG instead of a high-quality JPEG for such images would result in a large increase in file size with negligible gain in quality. In comparison, when storing images that contain text, line art, or graphics – images with sharp transitions and large areas of solid color – the PNG format can compress image data more than JPEG can."
    Source: Wikipedia
    The second is that JPG images can use various levels of compression. So for example, I took (the original of) this picture:
    ...and opened and resaved it as another JPG file, which is considerably smaller even though both versions are 6000 x 4000 resolution.
    However, the above screenshot of these 2 files in PNG is smaller than the same image converted to JPG.
    So horses for courses I guess. As most of the thing I am scanning are more image based, I have found JPG to be much better.
  10. soluna
    I now have made jpg photos from my new cassettes to add them to my "TDK-Cassettes" - Thread https://stereo2go.com/forums/threads/my-tdk-cassettes-collection.8611/page-10#post-94814
    The size of all 7 pictures together was about 22 Mb. After Batch-Convert to PNG with Irfan View ( There are compression-levels, i took level 8 ) size was 76 MB. Then i looked for "good compression of pictures without greater loss" in web, and found this https://www.iloveimg.com/de/bild-komprimieren . After compression i`ve got a size of about 5 MB for all 7 jpg together . Thats really a good result.
    Mister X and Experious like this.
  11. Experious
    Melbourne
    It should be noted that PNG is a lossless format, so different levels of compression should not change the quality of the image, but rather put more stress on whatever computer is trying to display it, although I assume that would be considerably less than with audio or video.
    Alternatively, JPEG is a lossy format, so different compression levels degrade the picture quality. The pictures you posted look fine to my eyes though.
    soluna likes this.
  12. soluna
    Thanx - and Yes ! , i compared before and after, was astonished about quality. And i`m for now not really enough experienced with Irfan...
  13. Hyperscope
    Vancouver Canada
    Donated 25EU. This a nice forum, even though I am seldom here nowadays, but I will support it for old times sake.
    I was always careful to use small resized and compressed .jpg files.
  14. Experious
    Melbourne
    I just noticed that the "Upload a File" option does not allow WebP format pictures. I tried changing the extension to see if it would display properly anyway, but the upload feature is obviously a bit more clever than that!
    If we can add this and want to keep ahead of the curve, it might be worthwhile adding JPEG XL (.jxl) too, which has recently been added to the stable releases of most web browsers.
    https://jpegxl.info/resources/jpeg-xl-test-page.html
  15. T-ster
    Lets not get caught up in file formats guys (its a great debate, but in a new chat), lets all focus on ensuring some donations are sent so the funds are in place to upgrade the server and upgrade the storage: DONATE
    Donation sent, whose next DONATE
