Sony WM-10/20 User
Discussion in 'Introducing myself' started by jmDc, May 16, 2017.
  1. Helaba
    Helaba Active Member
    Belgium
    Good work Boodokhan! Didn knew this one is not working without headphone connected.... How that works?
  2. Boodokhan
    Without connecting a headphone it wont work,. This is the way Sony made this walkman. I got some from eBay and they actually work (sellers didnt know about this fact)
    jmDc likes this.
  3. jmDc
    jmDc New Member
    philippines
    t
    thank you :wavey:
  4. jmDc
    jmDc New Member
    philippines
    many many thanks Boodokhan. finally i can now open my walkmans. so excited about it :headphones:
  5. jmDc
    jmDc New Member
    philippines
    hi boodokhan, what could be the problem if the rewind/fastforward buttons work but the play button only works for 3 seconds then automatically stops? thank you.
  6. Boodokhan
    Unfortunately do not have answer to this question. But hopefully somebody will answer
  7. jmDc
    jmDc New Member
    philippines
    thank you. hoping someone here has a similar case. still many thanks for the help :hi
  8. Helaba
    Belgium
    From my little technical knowledge, i think iT is something of motion control... If the walkman defects no rotation, iT stops after a short time...
  9. jmDc
    jmDc New Member
    philippines
    thank you. only the play rotation is defective.. it plays and rotates for 2-3 seconds then automatically stops. however, rewind and fast forward buttons all work well. thanks
    bronco likes this.
  10. Helaba
    Belgium
    Yes, because only the play function is motion controlled... IT can happen with a mechanical , or with a sensor places on take up reel.. On that reel you have different partitions ( light - dark) And when iT rotates , the sensor is constant on-off-on-off, so as long as the device receive pulses, iT command to keep working.... Oefoef..... Sorry for my bad English....
  11. jmDc
    jmDc New Member
    philippines
    Thanks again. So, is it still repairable? What should i do to make the play function works well again? Thanks.
  12. bronco
    bronco Active Member
    Spain
    I'd check S-901. It may be a mechanical (not optical) sensor.
    Something like a simple piece of plastic holding two "needles" touching a plastic wheel (probably take-up spinner) with a metallic insert that contacts needles every turn.
    There is a service manual :readon hifiengine (free)
