Sony WM-5 center gear?
Discussion in 'Tech talk' started by StaticAudio, Dec 1, 2017.
  1. StaticAudio
    StaticAudio Active Member
    The Netherlands
    I just received a Sony WM-5 which doesn't run.
    The belt has turned to goo but that is fixable (very dirty work btw).
    This model also has a center gear which unfortunately in my case is cracked.
    Does anyone know if the WM-DD series center gear is compatible with the one in the WM5?
  2. matic777
    matic777 Member
    Slovenia
    Pretty sure that it is comptible ....
  3. autoreverser
    folks, the WM-5 does definitively NOT suffer from broken centre-gears as the DD-models, it's inside a WM-2 !
    yes, it has got a centre-gear, but its different and NOT interchangable with DD-centre-gear, nor can you fix it f.ex. with Marian's repair-kit
    (...wich won't be necessary anyway, WM-2 centre-gears do not tend to crack, in fact within at least 50 units WM-2, 5, F2, R2, FM-2 over all those years i never
    ever had a broken centre-gear - that is mostly dissolved belts but unfortunately also defective motors...
    WM-5 rocks !
  4. buzbox
    buzbox Active Member
    Australia
    Agreed. Completely different and seems slightly thinner too.
  5. StaticAudio
    The Netherlands
    I also thought that these models didn't suffer from a broken gear, but the gear in my WM-5 is broken.
    But if this is not normal with this model I could look for a replacement out of a WM-2, as I gather from your answer.
    And if these gears supposedly do not break this would be a long time lasting repair!
    Thanks!
    Harry
  6. renzgi
    renzgi Member
    Switzerland
    The DD gear kit from Marian also fits broken WM2 and WM5 centergears.
    Regards,Renato
    autoreverser likes this.
  7. autoreverser
    didn't know that, thanks :thumbsup:
  8. mihokm
    mihokm Active Member
    Slovakia
    WM-2, WM-5 and Wm-F2 used two versions of gears in their models. Newer ones used modern (cracking) version of the gear while the older ones used old version of the gear. Usually, WM-2 models with "Walkman II" logo and green PCB inside have new version of the gear.
