Sony WM-D3 center gear replacement...
Discussion in 'Tech talk' started by flyingcircus, Sep 30, 2019.
  1. Mario Bono
    Mario Bono New Member
    NorCal
    I’m confused.
    It says Walkman II on the front and WM-2 on the door.
    Looks exactly like this one: upload_2021-6-14_11-56-39.jpeg
  2. JK1210
    JK1210 Active Member
    Cologne, Germany
    I replaced a CG for my WM-F5, I found there the same metal disc with brocken black plastic gear like inside a DD.
  3. Mario Bono
    NorCal
    Will the gear replacement solve the problem with the lever assembly? Or do I need to replace both parts?
  4. JK1210
    Cologne, Germany
    Normally it should. But sometimes lever is bent a bit up or down, sometimes also slider is broken.
  5. JK1210
    Cologne, Germany
    This might help if after gear replacement it doesn't work properly:
  6. Boodokhan
    I don't know why you removed the original picture but thankfully another member when responded to you placed the picture in the qoute
    anyway, The central gear in this picture doesn't belong to a WM-2 walkman.
    This gear that you show in the picture belong to DD walkman series (like DC2, DD100, DD30, 33,..)
    Your walkman will work if you find a gear that belong to WM-2
    If you place The DD central gear sold by mihokm or other sellers on this walkman IT WONT WORK. It has to be a WM-2 or WM-5 gear (both models use identical gears)
    to understand the differences between wm-2 central gear with other gears read the following topic to find out more.
    http://www.stereo2go.com/forums/threads/central-gear-wm2-5-vs-other-dd-walkman.5097/#post-38120
  7. Mario Bono
    NorCal
    Thank you. I’ll try these.
  8. Mario Bono
    NorCal
  9. JK1210
    Cologne, Germany
  10. JK1210
    Cologne, Germany
    It's the same but less expensive, if you buy from Marian's website directly. Should work.
  11. JK1210
    Cologne, Germany
  12. Boodokhan
    Apparently Marian made a gear specific to WM-2 gear. @mihokm is a professional and reliable advisor in this forum so I say trust this gear and go for it.
    meantime I would like to show you the 2 different gears of regular DD vs WM-2 gear from backside
    at left side you see a DD gear which a plastic component shells a metal disk and this is the main cause of gear to break.
    at the right, a very thin plastic that doesn't crack because there is no metal part inside it.
    and remember a DD gear will not work for WM-2 and WM-2 gear wont work for DD series.
  13. Mario Bono
    NorCal
    Thank you. I really appreciate all the time and advice from the members here.
    It sounds like my WM-2 has a (broken) DD gear in it.
    Any idea how that happens?
    I will try to locate the solid plastic WM-2 gear.If I can’t find that I will order the version above.
  14. Boodokhan
    maybe somebody sold you a wm-2 with a wrong central gear installed!!!
