Sony WM-EX606 Service and Repair
Discussion in 'Tech talk' started by TP86, Nov 18, 2026 at 9:19 PM.
  1. TP86
    TP86 Member
    Melbourne
    Hi guys.
    I purchase a good condition Sony WM-EX606 a fair bit of money. I have performed a basic service so far by replacing the rubber drive belt. After reassembling I am noticing there is only audio on 1 channel.
    I tried with a different remote and deduced the problem is not with the remote control.
    Before I try to do testing on the B-side of the board where the ic's and remote port wiring is located in which i believe i would need to bypass the hall sensor mechanism which triggers auto-off tape end detection, is there some far more simple anyone can think of? I'll have a look for dry cracked solder joints and report back if i find any
    Edit: I noticed some capacitor leakage. The small ceramic surface mount capacitor under the large black electrolytic actually came off when i touched it. It is C313. From the schematic C313 shouldnt loose the signal as it looks like a low pass filter or simmilar. Could anyone please confirm?
