The Infamous Marantz Mini Stereo Boombox CH-53/CP-53
Discussion in 'Chat Area' started by Mister X, Mar 5, 2018.
  1. Reli
    Sure that was 1980? Most of those radios on the lower shelves were not built until a couple years later.
    Your probably right, the units are branded UNIX so it would most likely match up when they were put on the market. Since UNIX seems to be mostly JDM, there's very little information on the build dates, a few fliers show up on Japanese Auctions once in a great while.
  3. WeberT
    WeberT New Member
    Biloxi, MS
    Hello, sorry for reviving an old thread. I have two of these and would like to get one working. Unfortunately they both have the same problem, can't power on the amp. Has anyone run across a repair manual or have some advice on getting started? Would be happy to hear it.
    Hello WeberT, you and I might have cornered the market on these fine units. There is a service manual for these, I saw one on Ebay a few years ago but it sold before my search. The ribbon connectors are kind of finicky, make sure they look like they are in good condition and all of the wires are making contact.
    One of my amps also wasn't turning on, after opening it and observing the on/off switch I did something (but I can't remember) to the switch. I might have cleaned the contact points, repaired broken solder, or sprayed DeOxit and that made it work, so I'd concentrate on that switch.
    These units take a specific 13.5 volt, 1.1 amp wall wart, it's huge, hopefully you are using that to power the units, I'm not sure what variations in voltage you can use if you don't have the original "Marantz" Wall Wart.
    The thread isn't too old, I still have a ton to add to it but work keeps me busy during the warm months. Post your units if you have a chance and if you have the CP-53 cassette player your a lucky person.
  5. WeberT
    WeberT New Member
    Biloxi, MS
    Hey, attaching a few pictures. You know it's funny, I had no idea these things were very rare. My dad picked up one when he was stationed overseas when I was a kid and I remember it sounding really great. At some point though I think one of the capacitors was failing because I think it would take a few minutes to warm up. I'm worried that possibly at some point after the cord went missing someone tried using a different one (ugh). Anyway now it ended up in my hands. The other system I happened to see for sale and recognized it as the one we had as a kid so I picked it up. It was missing some knobs and the amp on it won't power for some unknown reason. It also came with the original antenna and the case, which I didn't know about before but is missing the side with the handle. Also speaking of the ribbon cable, it looks like they lost the ribbon for this unit and tried to solder some wires between the pins.
    I don't have the cassette player. I do now have the original power supply, it's huge! The EQ and tuners for both seem to be fine. I'm hoping that between the two systems I can get one fully functioning and looking nice and clean again.
    I don't have a whole lot of experience troubleshooting electronics but I know some of the basics and I can solder. I'm in no rush, so I'll keep doing some more digging before I really begin, if I happen to find that service manual I'll be sure to scan it and post any other updates.
    Here are the pictures:
    (one of the amps is in a bag because I was looking at it and wanted to keep it all together, all of the parts are there)
    A little cleaning and some parts swapping and you should at least one nice system WeberT. I'd check the voltage on the wall wart and see if you get any response from the other parts. Hooking it up is fun, I think the power goes to the speakers first and they have a Y cable that goes to the main unit. Hopefully you have one good wiring harness and and two working set of ribbon cables.
    Thanks for the great photos WeberT, it looks like you added some new photos, hopefully you'll get a full set working. Now it's time for the three sets shown together, on the left is the Marantz System, unfortunately my camera doesn't highlight the "Gold Standard" the system has more gold color than the other silver units. This is all four components, all with the same footprint as the personal tape deck. Only three units will fit into the carrying case and I've come to believe that the amp and tuner with speakers were sold together and the cassette player and EQ were sold individually. This is still odd since the EQ only seems to work with these components but it does have input/output jacks and 9v battery power option, so maybe they thought you could use it with the cassette player.
    UNIX by Marantz is still a mystery but I believe it was Japan Domestic Market only since we don't see UNIX anywhere else. My UNIX Micro System is identical to the Marantz Version except for the printing on the front panels, it even has the full FM radio bandwidth and English Information Plates. Was there a UNIX Cassette Player to go with this? I think the PC-36 was the optional unit, I've seen three come up for sale world-wide in the last 10 years and they all go for big money, I don't follow the auction sites everyday so more might have been for sale but they are certainly rare.
    My mystery system came up for sale a few years ago, I don't know if the seller was member here or over at BBX and he didn't have a lot of information to contribute on these little systems. The system on the right is what I think as an early prototype version. Either someone scrubbed the UNIX Logo off the system and replaced it with Marantz Metal Badges or it's a very early system before they went into full production. You can see the marantz Badges on the units even though they have the UNIX Colors. If it was changed, I would think Marantz would bring more resale value but we may never know unless the previous owner chimes in. The cassette player is a Marantz/UNIX PC-30, a step below the UNIX PC-36 or AKA Marantz CP-36, the seller claimed this was the correct unit for this system.
    Hope you enjoy the system, I've included the BAM (big-ass-mic) and yes it's huge. I should have some more parts to fill in the gaps with this system and hopefully we'll keep these units from meeting a sad fate. My last quest is for a UNIX PC-36 but they are really going for silly money these days and have never been seen outside of Japan.
  8. stuck-in-time
    Jakarta, Indonesia
    I can confirm that the Marantz label is indeed original, as I own an identical unit. Well, half-own actually. Someone put up an ad for the cassette player last year, and apparently he didn't want to part with the rest of the system, as it's something he use daily. He bought it new in 1982 from the local customs office. As it was something imported then confiscated, I'm guessing it's for the Japanese domestic market. Recently he's willing to sell the rest of the set to me, but he's asking for more that what I'm currently willing to pay. Oh, and the set includes the equalizer too, just like the one in the center unit.
    As for the Unix cassette player, I've also seen, and missed out on, A Unix branded PC-30, complete with carrying case and speakers.
  9. WeberT
    WeberT New Member
    Biloxi, MS
    Hey just an update, I found another guy selling a partial set on ebay and went for it. This set had just the tuner and amp. Fortunately, the amp works! So I now have a complete working set again.
    Long term, my plan when I get time if I cannot find a service manual is to hopefully use this working amp as a reference for repairing the other two non-working ones.
    After years of searching I finally found another grail, not part of the Marantz Mini Component System but an actual brochure. My mule worked hard to bring me this treasure trove of Marantz Micro System Information, this is branded UNIX Mini Component Series. This is another S2G Exclusive, this may be the only copy in existence. The archivel packing for the brochure was very nice, unfortunately I need to get a translator to find out what all of this information says. For pricing I use a $50.00 USD to 5000 yen. There's no dates and the Buick/Oldsmobile looks like a mid-70's model. My scanner did cut about 3/4" from the bottom, there is more information down there I can post if someone requests it.
    I love that the brochure lists multiple configurations and prices out the options. One of my systems was supposed to have the "rack" but the owner couldn't find it. I'm still wondering what the added space was for next to the left speaker, looks like a design error. Also check out the UNIX PC-88DB Personal Cassette Player is also feature with this unit.
    More pages coming soon!
  12. Mystic Traveller
    Nice! :thumbsup: Thank you for sharing. Can I share pics with lads at Shizaudio?
    I've been known to appropriate some photos from the Shiz, but I like to give credit, the more people know about all of these wonderful websites, the better.
  14. Mystic Traveller
    Absolutely, especially given that we have now only a handful of dedicated and still really active sites, I would name 3 - S2G, ShizAudio and BBX-ry, for me that's all.
    Of course there might be some other ones (local in EU, Aisa, Japan, Aussie, you name it) I am not aware of, first reason here is the language barrier. :nodding::hmmm
    I wish I could read this it looks like they went into a lot of detail. The unit matched up with the PC-30 or PC-36 Portable Tape Players, the main difference i the players is the PC-30 cannot record. You can see the silver "hot shoe" on the PC-36, this is where the slide on stereo mic fits.
    The PC-36 came with a protective case, hot shoe mic and headphones with boom mic, I'm not sure what came with the PC-30.
    Check out the price, using the inflation calculator this comes out to $546.00 USD making this one of the most expensive portables at the time
    nickeccles, Papa and Mystic Traveller like this.
    The Buick or Oldsmobile is from the 70's so it's hard to date this brochure but portability was part of the package. I find the suitcase model boomboxes to be some of the most facinating, most of these are the top end models I imagine that were aimed at the travelling executive or musician that wanted the best music on the road. Marantz's Unit had an optional am/fm antenna that was very nicely made with weighted base and the back of the case held batteries for true portability. Check out the UNIX Branded Batteries! The case is metal-clad and will protect the stereo from abuse, the unit was sold without the case and these are seldom seen. It looks like the case retailed for over $100.00 USD back in the early 80's.
    ....and the last page, the top part is the case, and the components, the PC-30 and PC-36 are the tape players, now we know they are both part of the system. Add in a case or racking and your unit is portable, check out the headphones, I have to believe these are ultra-rare, mine aren't shown, they have a boom mic that came with the PC-36 Portable.
    I hope you guys enjoy this look into one of the rarest systems available. They do pop up for sale once in a while, but the tape decks are very hard to find and the EQ's are very close. There used to be a few members that had these systems years ago, they gave me the motivation to find and keep looking for the entire system. It really is a beautiful small stereo that deserves a back-story, I can only imagine what the guys in engineering were telling the higher-ups to get this approved. If you bought the entire system you were looking at $1600.00 USD (today's dollars). This was at Marantz's worse time, sales were down, they'd been sold and the new owner loved cheap all-in-one systems.
    Hopefully there's more to the story, post your systems and add any information if you have it!
    Found on the net, still no dates for this model, it looks mid-80s, but a pretty cool ad for the system, can anybody read Japanese?
    nickeccles and Mystic Traveller like this.
  20. Ralton
    Ralton New Member
    Mexico
    Hi, so during the quarentine I've been cleaning my house and in the attic I found one of this Unix Units I think it was my dads, I wanted to know if anayone could help me learn how to use it and how to connect it because its only the system nothing else. Either way here ar some photos.
