Hello everyone. I bought this device. Can someone please provide the belt dimensions? It is very difficult to get the correct value when measuring the old ones. It is not clear how much they are stretched. The same is also the Prosonic PQR 9962
Sorry, I looked around and didn't see any dimensions. We do have a seller on USA Ebay with the full kit. https://www.ebay.com/itm/256252565932
I've seen this too. It's very expensive for me in Europe. There are sellers in Europe, but you need dimensions. You'll have to experiment and order several dimensions for one belt.
Hi, I don’t know that particular model, but you could try WebSpareParts (www.webspareparts.com). They’re based in Europe and I usually buy belts from them. Some time ago I needed belts for a Luxman and they didn’t have the model listed in their shop, but they managed to sort out the two belts for me.
maybe someone needs it diameter 32 mm,0.85 mm thick diameter 31 mm,1.2 mm thick diameter 39.5 mm,1.0 mm thick diameter 37.5 mm,1.0 mm thick diameter 57 mm,flat 4x0.55 mm thick
