Panasonic rq s35 - high wow & flutter and speed is higher
Discussion in 'Tech talk' started by Raul, Oct 15, 2021.
  1. JUAN ANDRES MONTIEL DIEZ
    JUAN ANDRES MONTIEL DIEZ Active Member
    Spain
    Twin rotor motor, I cleaned it with contact cleaner and then dry well. I don“t think is a bad solder, likely the belt is not properly installed, due to its thinnes it's posibble it was so twisted.
    Raul likes this.
  2. Raul
    Raul Active Member
    Szczecin
    Mine is Silent Mechanism, they are a little different but I guess not in that regard :) Thanks. I will try that. I will check belt too.
  3. Raul
    Raul Active Member
    Szczecin
    Ok, so I cleaned the speed pot(?) with IPA. Did some cleaning here and there on the pcb and remade solder points close to motor. I can say than problem of speed instability on autoreverse is probably gone. Thanks guys for help.
  4. JUAN ANDRES MONTIEL DIEZ
    Spain
    Great! It's a very good and detailed sounding unit, enjoy It!
    Raul likes this.
  5. Raul
    Raul Active Member
    Szczecin
    Thanks. I really like it. Only one thing that is not so well thought is the push button to open cassette door. I will test ot more, but for now it seems the problem is gone
