Panasonic RX-DT505 tape mechanism problem
Discussion in 'Chat Area' started by mrn, Dec 19, 2016.
  1. Radio Raheem
    while you are in there i would clean the micro switches with contact spray as these oxidise and fail
    Mister X and kanamaster like this.
  2. kanamaster
    kanamaster Member
    Hello again. I don't seem to find the right way to place the protective caps back again. I introduce them on the contacts but they stay lose and if I invert the mechanism upside down, they will fall off. Now they are not firm as they were before removing them. Are they originaly glued, or what....?
    Kind regards.
  3. Radio Raheem
    all the ones i have dealt with in the past were not glued Sir....i think they kind of clip in....i am suprized you actually managed to change the belts, something i have never done with these so hats off to you:wink:
  4. kanamaster
    kanamaster Member
    Unfortunatelly, until now, I don't find how to clip them back again. I've tried and tried.......but nothing.
    In fact (if we're talking about a RX-DT505 or similar) once you take out the cassettes mechanism out of the whole unit, it is not complicated at all. As I said, not even those two "stubborn" connectors are really needed to be released. The only thing you really must do is desoldering the cables off both motors. Then you are able to "open the board" and easily gain access to the wheels where the belts should be placed. (There are two other little connectors which are very easy to release as well as a couple of screws.)
    Hyperscope, Radio Raheem and Mister X like this.
  5. kanamaster
    kanamaster Member
    Hello again...... Can anybody here help me with some information ("name" and size for example) about the screws I circle in the picture below? As you can see, they are the ones that fix the head mechanism. I am in the need of finding at least four of them.
    For any help, thanks in advance.
  6. Hyperscope
    Vancouver Canada
    There are very small protruding black plastic "pins" that snap off easily. Very easily. Then the clear plastic cover will not hold in place anymore. Held with little snap on plastic pins. Look carefully you should be able to see what I mean. Epoxy back on. But make sure to do it correctly!
    Overall very similar to the Panasonic RX-DT707 which I recently covered in the thread
    Panasonic RX-DT707 Cobra Top (1992) Changing the Belts with Pictures
    kanamaster likes this.
  7. Hyperscope
    Vancouver Canada
    Probably 2.5mm to 3mm and they were originally JIS Philips screws. Easy to strip. About 10mm length. I would send for a metric pack assortment on e-bay to test fit which ones work.
    Don't forget to post final pictures of the Panasonic RX-DT505 when it is all done and, most important, what you think of the sound. "Freaking Amazing!!!" is my impression of the RX-DT707 at least :biggrin: :thumbsup:
  8. kanamaster
    kanamaster Member
    You said it all. It's also "freaking amazing" how the RX-DT505 sounds (and records) for this category. And I must add that they (505, 707) are evrything but easy to find in Germany. Kind regards.
  9. kanamaster
    kanamaster Member
    This is the first one that I bought some months ago, and which made me want to have a second one. That second one is the one that still is under repair (not in the pictures). Not too much time and several other things in which I must invest that very time.​
    Hyperscope likes this.
  10. kanamaster
    kanamaster Member
    Two of my favorite babies......
    Hyperscope and Radio Raheem like this.
