Hello everyone, my name is Marco and I am trying to repair some old walkmans, including Aiwa TP-550 Panasonic RQ - L335 Philips D6606 Sanyo (an ultraslim model) Sony B47 Toshiba KT-4117 I'm doing this because I would like to transfer the content of some cassettes to a computer without using the new USB players sold today. This forum contains a lot of valuable information and I hope I can also get some help from enthusiasts!
Welcome to the forum! In the early days of digital I spent a lot of time uploading cassettes to my computer. There was a few programs I used but Sony Acid worked nicely and was free for some reason. I could cut the songs apart and sometimes for fun I'd take out the vocals. I think I was just going through a MIC input on the computer.
Thank you for your answer! I also can't wait to listen to some tapes again. As for the recording — as soon as I'm able to fix my Walkman — I'll use VSDC (a free video editing program, which I also need for other things), a regular audio cable, and an attenuator bought on Amazon, which I believe is necessary to prevent the recorded sound from having saturation and distortion.
Welcome to the forum, Marco! It’s been years since I ripped any analog music to a computer, but I remember this great program I had years ago called ‘Audio Cleaning Lab’ by Magix. Magix made a lot of great software back in the thousands, but Audio Cleaning Lab was the best. What was so cool about it was that it had specific modes for ‘decrackle, depop, dehiss, and denoise’, and it wasn’t just the AI rubbish we have now, it was actual software noise processing that had amazing results when used with records or tapes. When used in moderation, you could make a chrome tape sound almost like a CD! It also had TONS of plugins for signal processing, dsp effects, and eq. You usually don’t need anything fancy for this work hardware wise, just a good sound card with line in (SoundBlaster XFi or another decent spec card), and good speakers/headphones to be able to react to and adjust/tweak your recordings. Most sound cards have attenuation built in, and any recording software (plus even the Windows Mixer) can control the levels so that nothing gets too hot and distorts. Adding in a physical attenuation control would be a nice convenience bonus, but it’s not a requirement. Last thing I would add here… I know we are a portable audio forum, and I love portable audio, but if I was trying to get the best results possible, I wouldn’t be using a Walkman as a source player to digitize tapes from. You really need a proper line level output rather than just a headphone out for the best quality, and the wow/flutter of a Walkman usually will not compare to a good older tape deck. With that said, based on my quick research of these models you posted… the Sony (with MegaBass off) you listed would probably give you the best results if you don’t have a tape deck. I’m not sure the Aiwa TP-550 or that Panasonic is Stereo, as they seem to be cassette voice recorders. Good Luck!
I looked up Sony Acid Info and they were bought out by Magix. I used to use either a JVC or Sony Component Deck to transfer the music back then most of the decks I found still worked fine, not so much anymore.
