Good day! I am in the process of restoring the above-mentioned player. The player came to me in mint cosmetic condition. It turns on, the laser moved up and down, the laser was visible but the spindle didn't turned and then showed E on screen. I am well aware that it uses the dreaded RCD-2 laser assembly, and as such it was the first thing I checked. It wasn't necessary to disassemble the laser. The aluminum housing was corroded even on the outside, and as such it was visible even without removing the focus lens. Oh well, that was part of the gamble. However.... I happened to also have a functional Philips AZ6811, which uses the same laser. The unit used to work flawlessly, but it developed the habit of smashing the laser sled against the inner end-stop before reading the TOC. Afterwards, the sled failed to move outwards. I checked its laser and it is surprisingly clean. I removed the focus lens, but didn't thrust myself to disassembly any further (I do not want to mess with the alignment of the mirrors). But outside, the aluminum looks healthy, and peeking through the hole for the laser, it looks clean: https://photos.app.goo.gl/tS4FeTrNW9FG1nVC9 I assume the problem with the AZ6811 is capacitor related (the motors work, and so does the limit switch), but replacing them is particularly annoying on this model. They are all sandwiched between two PCBs who are soldered together. To access the caps I need to remove a bunch of connections between both boards, remove a bunch of glue and it is not worth it. As such, the 6811 became a donor for the 6806. I swapped the laser from the 6811 into the 6806. I then reassembled and had exactly the same error. The spindle never starts. Knowing that the 6811 read the TOC of 3 different discs just 3 days ago, it is safe to say that the laser is probably healthy. I wanted to go into service mode in the player and check if everything works. I know that the spindle motor works (tested it with an external power supply), so I wanted to discard/confirm if any capacitor might be damaged, or if the issue is laser related. But then the conundrum started: 1. I've not been able to find a manual for this model. Nowhere. 2. I checked square2.com's PDCP component database, and to my surprise the AZ6804 and AZ6804 are listed as the same model (this I can believe given how similar they are, main difference is the lid and the buttons). 3. I do have a manual for the AZ6804. A quick comparison of the PCB schematic seems to indicate the mainboards of both players are identical, but I would like a confirmation from someone familiar with these players. 4. The 6804 manual states that to enter service mode, PREV and NEXT should be pressed while turning on the player. This button combination does not work on the 6806, nor does STOP and PREV (used on the AZ6811). I tried a bunch of combinations, and none worked. As such, I am considering using the 6804 manual and try to pin-point which electrolytic capacitors, if any, could potentially be affecting the movement of the spindle. I know that both the spindle and sled motor are driven by the same IC, and the later works. As such, I am not really sure if the issue could be capacitor related. But it is worth a try. Worst case, the laser is also damaged. But given that it worked without issues not so long ago, and that a few days ago it read the TOC suggest that, probably, the donor laser is in good shape. Any suggestions or hints are highly appreciated.
Reviving any Philips portable CD player must be classified as a Lifetime Achievement! Starting with their incredible CD10 and for over five years Philips kept discovering the most incredible ways of doing simple things in the most difficult way! Last week I received custom 3D-printed parts from Shapeways.com (Netherlands) and, finally, my Philips AZ6808 plays CDs again! Project started last Christmas and while working on and off this AZ6808 I also fixed AZ6806, AZ6817, AZ6893 and AZ6897 Tips for those crazy enough to follow: (A) no need to worry too much about Service Mode - quite a few Sony and Denon players which I restore on a regular basis refuse to enter Service Mode but otherwise play perfectly. I have Absolutely No explanation to this! If CD player does not recognize CD, then SM does not help at all - CD just spins at full speed and there is nothing to 'calibrate' (B) I bought AZ6806 Service Manual, here is a photo at highest rez allowed by S2G. Full iPhone rez is here: square-2.com/wp-content/uploads/2026/11/Philips_AZ6806a-scaled.jpg Let me know if you find any differences with AZ6804 (C) AliExpress sells "Middle Gear" which disintegrates in practically all RCD2 laser mechanisms: TracingGearPhilipsRCD2 I bet that 'working laser' mentioned in the OP needs a new gear because exactly the same thing happened to me more than once. Infamous Orange color, dreaded by all Philips boombox owners: (D) RCD2 laser itself is the part which turns BAD, now we are getting to the tough step. I bought a few NOS RCD2 lasers from AliExpress - they all were Bad. I got a partial refund, you might get lucky but I did not. Two options: (1) send to Kaosun at kaosuncd.com and he will fix and align it for you (2) Philips/Magnavox models AZ6811, AZ6812, AZ6813 have the same RCD2 laser, and these are dime-a-dozen. I bought about twenty of these, and with a new Middle Gear some came to life, just enough to fix a few Philips Discmans for my own collection
